How to bleed Combi 90 boiler with tigerloop
4 May 2017
We ran out of heating oil 3 weeks ago and had a new tank installed as the old tank was cracked. We had new oil delivered but the boiler will not reset. Ive pushed the timeout reset button twice. I assume it needs bleeding from other forum posts, but i don't know how to do this. Do i bleed it from the tigerloop, or from the boiler itself?
You need to take off the suction pipe where it comes from the valve and dip it in a container of oil run the burner for 8-10 second stop the burner reconnect the suction then run the boiler should run ok.Bob
