I would rather buy one from a shop instead of ebay. If you do have problems with it not working you will have no problems sending it back..
John..
That's true. Also I would make a best offer well below £18 so as to be clear of import duty.
John..
I went the other way and bought cheap jobbies which didn't work so I gave it up.I have owned a few hdmi splitters (1>2) i tried the expensive ones first The first 2 i bought were over £200 each and they were useless. I ended up getting one of the £30 splitters and it worked perfectly..
John...
I stuck it in my basket right off the bat!!Try the amazon one, it will work
John..
Yes but I need to service two screens!! That requires two HDMI outs.The expensive option: AV Amp. I have 2 HDMI going into my AV Amp, and one HDMI out to my TV. AV Amp is only really worth considering if you have a semi decent home cinema set up, and/or lots of devices to plug in and manage.
A av amp is no use unless it has 2 hdmi outs. These start from about £700.
John
Yes, like this.you should try shopping around, there are plenty for less than £700, with enough output options to satisfy all but hardcore AV freaks
