I am planning the installation of a thermal store in my house. I am thinking to use a plate exchanger for DHW. One problem compared to an internal coil is that for full output the flow on the store side of the exchanger has to be quite high, which disrupts the stratification of the store. I would like to therefore modulate the flow rate on the store side of the plate excahnger based on DHW demand.
I was thinking a reliable way to do this would be to throttle flow on the store side of the exchanger based on the temperature of the water going through it. This could be done with a thermostatically controlled valve, and a pressure modulated pump, such as a Grundfos Alpha 2. It would also eliminate the need for a flow switch on the demand side.
My question is does anyone know what valve could I use for this purpose? It would be like a large TRV but would need to depend on the water temperature rather than the air temperature. Perhaps a normal TMV would work with one leg capped?
