Hi Guys,
Would someone be able to advise on my queries, a bit long winded but hopefully will make sense.
I am thinking of changing from Scottish power (Comfort Plus) to Scottish hydro (Economy 10 plan)
This involves having the two meters and the radio teleswitch removed and a single rate meter installed before I can apply to transfer the supply, then once changed apply for an economy 10 meter, all of the process will take 2 months at best and 3 months at worst so i would have to act now.
Without a radio teleswitch what would be the best way to control the storage heaters together so they would charge up during the cheap period, I can get good quality individual time switches rated up to 3kw for the smaller 1.7kw and 2.5kw storage heaters but cant find anything that would be rated high enough for the larger 3.4kw model.
Reason for changing / other information:
I moved into my current house more than a year ago and its all electric with 3 storage heaters, panel heaters in the bedroom and fan heaters in the toilet, bathroom, kitchen and electric fire in the lounge.
Not a heavy annual user with 4200 domestic units used (£454) and 6081 heating units used(£318) so only £65 per month.
Having run the storage heaters for a winter (Nov - April) I did find that they could run out early evening but as they kept the house warm all day and the house was occupied during the day this was OK. The house wont be occupied as much during the day over the next winter so having a 4 hour charge period during the night (4.30 - 7.30) and 3 hours top up in the afternoon ( 1.00 - 4.00) with an additional 3 hours in the evening if required (8.30 - 12.30) would suit me better
I would also be able to take advantage of the cheaper rate for the washing machine, dishwasher and tumble dryer as well as they all have delay timers.
I did have 3 days last winter when the radio teleswitch was not activated and left the house with its main heating but it generally seemed to come on at 11pm go off at 3am and come back on again at 5am and go off at 8am.
Also,
Scottish power have said that the heating circuit would not be active if changed to a single rate supply so I am assuming that they would just leave the existing domestic circuit alone, The current domestic meter is rated to 80amps and the heating meter is also rated to 80 amps both fed from individual mcb's. Can you get a meter that can handle more than 80 amps as i would like to have everything connected so we could have hot water etc whilst changing over without having to arrange temporary rewiring.
Any help would be much appreciated
DFH101
Also,
DFH101
