Hi
I need to replace the engineered floorboards in our kitchen but the units were fitted on top of wall to wall engineered flooring.
I don't want to remove and refit all the units so am trying to work out how to cut away the flooring up to where the feet of the units touch the flooring.
I can remove the kick boards and the end panels easily. I need some sort of shallow circular saw that is shallow enough to fit under the units. Most of the mini circular saws I've seem come up at too much of an angle to fit under the units.
Does anyone have any tips as to how I can do this? I tried one of those multipurpose tools with the half moon saw that reciprocates very fast but it takes forever to cut through the boards. I am thinking something like one of those dremels with the circular saw attached but they're not powerful enough. Maybe an angle grinder with a wood cutting disc fitted?
Any advice gratefully accepted.
