did you say it was concrete or boards underneath ??
if its boards then it will not damage the blade unless you hit nails or screws
you will just damage the boards
well just be very careful
it will help if you can push say 3mm hardboard in the area but to the side to raise flooring and give you a buffer
but not to far away as it will cause vibration and not to close as it will add to the cutting
