hi guys
Does anyone have any suggestion for our plumber to find a leak in our pipe work?
Background:
New Worcester 30CDI system boiler fitted in September with new rads but using existing 15mm pipes to rads and fitting stat to existing insulated water tank. Move from gravity fed to pressurised system. Tube of fernox sealer fitted after testing of system just incase of any small leaks. Any small bits of new pipe work at rads/running to new boiler location plus all valves are leak free. The Worcester accredited installer has offered to put another tube of sealer in. We are losing 0.5 bar over a 2 week period (or a bit less).
Issue 1:
The engineers at my work (don't work daily on domestic boilers) woukd be reluctant to put in more sealer as they think it would gunk up the TRV's etc. They have suggested getting the plumber back to pressure test the system, taking up to 3 bar slowly and listening for the leak.
Is this the only/best way to find the leak?
We know we will need to pay for the plumber to do this as all his joints are clean and it's possible we have a joint that has been leaking for years.
Issue 2:
We are using between 12-14 units per day on these cold days. Heating on to 20degrees on programmable stat for 6.5 hrs per day. Water timed for 4 hrs a day with stat on HW tank. We have 11 rads and 2 towel rails 180 sq meter house and it is not mega warm. Never even reached 20 degrees in the hall tonight (where stat is) and rest of house not even cosy. Although, we need to top up the pressure again. It's costing about £5 a day on this usage which coukd be £100 a month in the winter, which seems excessIve. I thought we woukd save money with a new boiler. Unfortunately I only moved in June so I can't compare bills fir last winter. Does this seem reasonable usage or could it indicate another issue?
Any suggestions we could get the plumber to look at?
Many thanks for any suggestions
Fluff
Background:
Issue 1:
Issue 2:
Fluff
