This thread is for people Googling 'Techflange' as I did. It describes how to fit an Essex flange style Techflange (click me for example) to a hot water cylinder. I'm very much an amateur DIYer, and a total plumbing novice. This was my first 'big' plumbing job. I hope someone finds it useful.
My system is indirect vented (y-plan).
The flange arrived and it looks like this. It loops upwards to catch the hottest water at the highest part of the cylinder. I fitted the lever valve beforehand, so if I dropped it it wouldn't fall through the cylinder:
I started drilling the hole using the supplied hole saw. I read and re-read the instructions and followed them to the letter. The only problem I had was that the supplied hole saw was poor. Blunt, teeth wildly off centre, one tooth sticking out at 45 degrees. So I braved my 3 year old hole saw set and it went through no problems.
I was concerned that the copper was a different colour nearer the seem...not sure whether this is due to the extra heat there or because it's thicker, or what. At one point the cylinder looked like it was buckling under the pressure I was exerting, so I backed off and used slightly higher revs.
The hole saw comes with a circle template. Use this to mark the position of the washers. They must be central to the hole you cut for stability of the connection.
Drill a small pilot hole. Then take the hole saw with centre drill and go to work on the cylinder. Use medium speed with fairly firm pressure. Be careful and take it steady.
Thankfully the biscuit stayed on the drill bit. Even if it makes no difference, I'd have been peed off if the copper disc had fallen in.
The flange section in the star shape is designed so that you can manipulate it through the hole. Bend the split washer slightly and rotate it on the pipe so that it goes through to the rear of the cylinder, then stuff the rubber sealing washer through the hole just by squeezing it and pushing it through. Now tighten the nut as hard as you can by hand, then turn another 1/2 (max) with a spanner.
Flange fitted:
Close up of flange:
Very close-up of flange, note the red dot so you know where the upward bend is pointing inside the cylinder:
Pipe work, not sure on how correct that run of pex to the mixer is:
Pipe work:
Hope this helps someone. This is THE best way to connect a hot cylinder to a shower pump. No air, dedicated full bore 22mm feed, takes the hottest water unlike a standard Essex flange. The pump is a 1.5 bar Salamander CT50+, so this setup might be considered overkill. However let me tell you, the pump is damn quiet and flow is excellent. I'm no expert, but connect the hot correctly (not off vent pipe) and you'll be grateful you did. Imo this method trumps Surrey and Warix as an installation method and if like me you'd need to re-plumb the vent pipe to accommodate a Surrey, then all the more reason to fit Essex.
Any questions, let me know.
Flange fitted:
Close up of flange:
Pipe work:
