Never the less I would say this thing is going to be "pulled away" rather than "pushed down". Someone is bound to use it to climb up one day, put the Christmas lights up or something, and it will pull out of the wall.
Shield anchors all the way through the brick?
I'll wait for someone who knows to confirm though.
Yeah I can see where you are coming from now. To be honest I'm not a builder but my dad and brother are and seen then using these type bolts for lots of things. I just wire stuff up and join wood and stuff. Maybe a Epoxy resin fixing would be a good fix for this type job? If these self tipping bolts are used right you get a very good fix. But on this type job it seems epoxy wins.
My neighbour had his bedroom window taken out and doors and a JB fitted but he had it made so the whole bottom bolt holes was lined up with his joists which he marked out when he was doing the room, anyhow he had bolts ( not sure what they are) going right through the brickwork and into the joists, I will ask what he used for the side bolts and get back if its not to late
