Hello Everyone.
This is my story of woe.
Last year, I successfully installed, programmed and commissioned a Honeywell Galaxy G2-20 system, with 4 wireless door sensors, RF module, external Bell.
The whole system worked like a dream for over 13 months. Then suddenly I was unable to set the system due to an RF problems wrth the front door wireless sensor.
The door sensor would sometimes say it is open when the door was closed and sometimes vice versa.
I changed the battery in the sensor, but to no avail. I then thought to change the sensor as I suspect there may be something intermittent with it.(I bought a spare).
But I cannot remember how to get into the Engineer mode so that I can access menus 50 and 60. I did enable LVL 3 mode from option 43 then enable.
I suspect that I have attempted to use an incorrect Engineer mode pin, as i cannot remember for sure.
What I need help with please is the correct procedure to totally reset the whole system, so that I can start all over again, as I did when I initially installed it using the manuals.
Best Wishes and Thanks in Anticipation.
