I have used Dulux Satinwood white 'wash brushes with white spirit' version on the whole house woodwork and loved it until the new regulations for reduced solvents seemed to ruin paints of all types.
I feel the water based satinwood is a cold translucent white, difficult to get good finish with brush or roller and is very difficult to sand down years later, an odd acrylic type surface! So I have steered clear of that.
So I have the solvent based one but struggle to get a good finish with foam rollers like I used to do. These low solvent ones are very different and don't form a level surface the way the old ones did, very unforgiving. They are also very slow drying! The undercoat some years back when these new low-solvent ones first came in took nearly a week to go hard, tacky to the touch for many days.
How do I get the very best finish using the solvent based satinwood? I have tried pain pads, mini foam and fleece rollers. But often I get a stippled look finish that doesn't level out with drying. Never had this problem with the old (higher solvent) version.
Any tips please? Can it be slightly thinned??
Many thanks
Thanks. Sikkens is definitely not cheap but that is secondary to it being the right product. It sounds like for a water based paint (and they will definitely stay white) it is still good to work with and produces a good finish.
Products like Dulux Diamond have been recommended by some but then others give poor ratings for application and finish. My previous and only experience with water based white satinwood was 15 years ago with a Dulux, it was quite translucent and didn't block out what was under it. Hopefully the Sikkens is much better.
If it was any other colour then the low solvent satinwood wouldn't be an issue but with white it seems a big problem - for all brands, reports of yellowing within months are quite discouraging. So it looks like water based from here on for white.
Q - Do I apply the Sikkens water based in the same was - roller then brush out with a synthetic brush?
Thanks again.
