Crow foot spanner.Any suggestions?
Yep, that would probably have done it too. It's just irritating having to buy a tool for 1 useCrow foot spanner.
When I fitted my bath, I needed an adjustable tap wrench for just two turns of a nut. I bought one from B&Q along with a lot of other stuff. I didn’t remove the tag, tightened my nuts and took it back for a refund.Yep, that would probably have done it too. It's just irritating having to buy a tool for 1 use
I've a few tools I've only ever used occasionally - but they can still pay for themselves. In your case, a few quid on a basin wrench is a no-brainer to me because sometimes, there's no better thing than the right tool for the job. You could also have bought a half-decent multi-tool for around £70, and it would still likely have cost you less overall than a plumbers bill for this job. Unlike the basin wrench, if you do much in the way of DIY, you'll probably find a multi-tool is a genuine investment and you'll wonder how you ever did without one. I've had my Bosch mains one for years and it gets used for all sorts. Pleased you sorted it.All - many thanks for the further suggestions, esp the wiresaw one - that might have got in between even if a hacksaw didn't.
I was loth to buy a basin wrench (or any tool) for a single use but luckily got lent one. But even then the access was bl00dy tight - would have been better off with the 8-in-1 tool! Why DO they design these things like this - I thought the air-suspended Citroens I used to drive were bad enough!
Kind regards, Mark
PS: And yes, if I'd known at the outset how it was going to go I would have paid someone!
Get a cordless multi tool with a metal cutting blade, much easier than a hacksawHi all
Am trying to fit a replacement bottom-entry flush valve in my toilet cistern - that's not the issue.
What IS the issue is that it's a close-coupled one (didn't even know what that meant before today!) and I have to get the cistern separated from the toilet bowl so i can unscrew the old valve assembly and replace it before reattaching the cistern to the bowl.
Here's the problem: the cistern is attached to the bowl by the 2 bolts/screws you can see circled red
in the photo BUT they are rusted solid plus the access, as you can see from the pics, is extremely limited. I have pulled away the rubber washers that were there originally, plus chewed away at the screw heads as best I can with pliers / claw hammer etc but the lack of access, plus the fear of cracking the ceramic cistern/bowl, means I'm currently stuffed. What to do?
HELP!
Mark
Yeah, I would have done that (and have on occasion!) but the basin wrench, from the place i was looking at buying it from, was packaged in a way that prevented thatI bought one from B&Q along with a lot of other stuff. I didn’t remove the tag, tightened my nuts and took it back for a refund
