Hi all,
After much thought I have decided it's best to replace my Sonos Play 5 with a spare Connect:Amp and some in-ceiling speakers in the kitchen primarily for stereo sound and to avoid the power cable from the Play 5 to the socket.
I have attached two images showing the ground and first floor directly above it. My thought is to put the amp in the pantry under the stairs where there's power for the amp. There also looks to be a hole in the ceiling in the pantry where wires are fed and seem to appear under the floor boards at the top of the stairs.
On the first floor the hallway has floor boards running from top to bottom so I assume joists running from left to right? The bathroom has lino laid so I can get to the floor boards and I would like to avoid fitting a speaker below the back bedroom which will be used for baby number 2 when it arrives.
If I put the amp in the pantry how easy/hard is it to "fish" the speaker wire to the position I would like to put the speakers (blue circles) keeping in mind the joists etc?
Can the fact that I have a dozen or so spot lights help with fishing the wire? Can these be popped up so that I can get to the space above it?
It's a Victorian house with high ceilings and coving and I cannot tear down the ceiling. I thought about taking the floor boards up in the hallway but I would only be able to put speakers down which sit above cupboards and wouldn't look as good nor probably sound as good.
I have access to the attic. On the first floor you can see the dashed lines which indicate walls. Is it possible to drill down into the wall from the attic and pass wires down into the space between the ceiling and the floor? I can't imagine how I would then locate the wires to pull them towards the speaker holes.
Also, to apply with building regs I believe that a "hoody" is required to assist with keeping the integrity of the ceiling against the spread of fire. Although I'm sure many people don't do this I would prefer to do it by the book just in case we sell the house in the future....
Help would be truly appreciated!
View media item 62813 View media item 62814
