How to make an F30 door
Many fire door blanks can be cut down to suit a non standard sized opening, the door will need to be lipped with a hardwood bead on any cut edges, it will likely tell you what is required in the specifications or data sheet.
Yup you are correct.
I emailed them and they said that it will need lipping.
Mind you, in post #14 you showed the text from their site anyway.
I believe it is usual to neatly saw off the factory lip, trim the door, then refix the lip.
