Thanks for the replies guys.
Hot rod I would consider something similar like a soldering iron.
But would prefer drilling
The drill I uses was a wooden drill bit. If I used another type, maybe would be better?
Adding wood sounds perfect - but then how do I do the same job again 100 times?
Really complex and hard to follow
Any chance of a video?100% this
if you have loads make up 2 jigs
the face board needs to be deeper than the amount the drill point is protruding although once the wooden face discs have been cut out and removed from the face jig you dont need a auger/drill bit at all for holes sticking forward so can be cut short /retracted or removed dependent on design
this board can be cut to fit snugly between those ribs and the lip at the top
the inner one will be probably fitted to the width and base probably with shaped edges to locate accurately
you then with a solo clamp away from the drill area clamp them firmly together
the first 4 holes in situ will make the jigs complete as in the outer jig plate will now have a cut hole with a auger/drill hole on the inner plate
once set up you will only have to empty the hole saw off plastic discs every few boxes at the point the cutting teeth have less than 5mm behind them full off plastic
