How to make holes in plastic boxes?
Adding wood sounds perfect - but then how do I do the same job again 100 times?
get a board of 18mm ply
cut it to fit inside the box, so it goes down to bottom -chamfer edge as needed, put it in place, then screw a batten on the ply so it sits against the top of the box lip
then take out the ply, drill 4 holes (size of centre drill in hole saw to match the position of the centre of the holes
then drill the holes
the problem you have at the moment is when you drill in the centre drill makes the hole bigger so there is no centre guide for the drill and it wobbles
If I used another type, maybe would be better?
Maybe a finer toothed one but like I said, run it backwards
Take a piece of wood and use your hole saw plus pilot arbor to drill a hole in the wood and just let the hole saw run into it maybe 2mm, so you end up with a hole in the wood with a circle groove around it. Clamp the two together well without your hand or indeed a clamp
Position the wood behind the plastic in the place you want to drill as guided by the circular groove, and then, running the drill backwards, drill the pilot through the plastic so it drives into the hole in the wood. The hole saw should gently make a hole
Running it forwards will be too aggressive
Diamond core bits could be worth a try and not shake around as much
Thanks for the replies guys.
Hot rod I would consider something similar like a soldering iron.
But would prefer drilling
The drill I uses was a wooden drill bit. If I used another type, maybe would be better?
Any chance of a video? :)
Really complex and hard to follow
sorry find it close to impossible to even post a picture
may be some other kind sole with an ecosse to english translator can work it out and do a drawing :unsure:
I doubt they'll work. I think the soft plastic will just clog the abrasive face - leaving you with a smooth tube. So you'd need to run it fast enough to heat up the plastic and melt a hole through like the hit metal pipe method previously mentioned.
And if you do that, cheaper to just use a bit of metal tube.
Do you have a smartphone? On mine I hit the camera icon above the writing box and it asks me if I want to take a new one or use one out of the phone's memory, then uploads it job done..
