- Joined
- 10 Jan 2008
- Messages
- 34
- Reaction score
- 0
- Country
Hi everyone. I've read lots of posts about core drilling and stitch drilling, but not entirely sure what to do in this situation:
We are about to replace our ancient kitchen. We need to put ventialtion for the cooker hood extractor through the wall. We have been supplied with a 3m ducting kit, which ends in a rectangular tube to go through the wall. Obviously this is designed for brick walls where you simply take out a brick. If only it was that simple
We have half meter thick stone walls, built late 1800s. Which are random stone, and seem to be rubble filled where I've already put through some 20mm holes for other pipes. (which was NOT fun )
I have also core cut breeze block before, but never stone.
What is the best way to cut the rectangular hole required?!
I am thinking of either drilling 4 pilot holes in the corners as a guide, then using a diamond disc & angle grinder to cut the outer stones out reasonably 'neatly'. Followed by the enenvitable drilling and chiseling to remove the middle 'rubble fill' of the wall.
OR using a core cutter, cut probably three cores through, the square this out with an anle grinder and SDS drill/chisel again...
Both seem quite time consuming (but I don't mind that) and will require making good after. Is there a better method?
Also - once I do have some sort of hole through the wall, is it good enough to simply push the square plastic tube through the wall and then make good around it? Or should I try and mortar the tube in place, or use expanding foam or something else? Is there a danger that any rubble can move over time and crush the plastic?
Most importantly (probably just being paranoid) is there any chance I will weaken the wall?
There is an old wall mounted extractor fan which we will be removing (on the other side of the kitchen so no chance of re using that hole unfortunately) where I can see someone has just smashed through the wall and made good after, so presumably it is possible...!
thanks in advance for any advice!
