- Joined
- 17 Sep 2008
- Messages
- 41
- Reaction score
- 0
- Country
I want to get the right size fitting for a copper water pipe. The house was built in the 80s I think. The pipe used to be connected to an immersion tank, so it is I think wider than pipes attached to taps.
Internet surfing suggests that pipes can vary in size by 1/8th of an inch if imperial, and then there are metric ones as well.
Is there any easy way to measure them? Should I measure the internal or external diameter? Would it be likely to be one particular size, from my description above?
