I want to try and install a new sink in my garage. The other side of the wall is my washing machine with a hot and cold feed and a waste pipe which goes through the wall and down the side wall of the garage outside.
My combi boiler is also in the garage and hot/cold water pipes (separate to the washing machine pipes) also run up the garage wall to the house.
I assume I can connect my sink to the existing waste pipe in the garage that the washing machine uses?
Can I also feed off the hot/cold water pipes that are the other side of the wall? I can't see an isolation valve, so do I turn the water off at the mains, drain the system, then do I cut the pipes and fit a tee on each pipe to go through to the garage?
Is it as simple as that?? I'm guessing not...
Any help appreciated.
