I want to install some 12V LED lights into the wall in my mother's garden. I plan to chisel away the render to allow me to fix frosted acrylic tubes in which I will place several LED strips. I'll then render over the connecting cabling so that the tubes are set in the wall. The main issue is the electrical source. The LED strip lights come with a transformer which plugs into the wall and a controller which plugs into the transformer and responds to a remote control for dimming or changing the hue.
I suppose I have a few options. The simplest but also the least clean would be to have the a cable exit the building through a hole drilled in the wall. The plug would then be placed in a socket. I don't really like this method but there's a good chance I'll end up using it.
Atlernatively, what would be sweet, is to connect the LEDs to the mains, probably via some other transformer (max 50W needed assuming that I don't later want to add more lighting) so they could be switched off via a switch in the kitchen. There is already a lamp fixed to the wall outside with a switch on the inside wall so it wouldn't be too-difficult a task.
How much do you suppose it would cost to have an electrician make the appropriate connections to give me a 12v supply? Would they also need to check the lights before I added render?
