Asked in Tile Giant for this trowel and they only had square ones
What size? So are you saying your tile shop only had one type & size of trowel!
no they had different size square ones but not one single round one, which I thought was odd, they were all on the wall to look at.
but they seemed pretty certain it was much too big.
Much too big for what? Did you explain you have large format tiles on an uneven wall which needs a powder addy!
Yes I did explain to them, but then they are sales staff not tilers so I just use their input to help me make my own decisions. Obviously you hope they know a bit as they supply the stuff to professionals all the time but at the same time I would not take their input as gospel.
so I went to Topps Tiles as they were nearby and they had all sorts but agin did not have the one you suggest, but they also thought it was far too big.
Ahh Topps my favorite
; again far too big for what? It’s well known that, apart from B&Q, their counter staff are among the best experts in the tiling trade.
As above I suppose, although they do seem a bit better than Tile Giant.
both places suggested a square 6mm after I explained that I had a flat render/cement based surface, i was trying to get them to suggest bigger by saying the surface was a little rough which render would be so that they would suggest the one you said but they seemed sure it should be only 6mm.
A 6mm square notch @ 25mm pitch will give adequate bonding in a dry area on a perfectly flat tile base. In a wet area you need something a bit larger, 10mm wide x 6mm notch @ 12mm to give the required adhesive coverage. Again, you have large format tiles (which need a powder addy) on an uneven wall & in a wet area!
Also what happens if you do put on thicker adhesive than you need?
You will waste it; but local circumstances may make it prudent! Powder addy will stand much thicker applications than tub mix which is a big benefit on uneven wall surfaces. The amount of addy you use is directly related to (or should be) the size of the trowel you use which is dependant on the requirements & local conditions.
Whats the difference between the shapes, ie what difference will it make using square or round trowels, just interested?
The coverage of the adhesive under the tile. I only ever use a round notch in wet areas; square notch will not give the necessary 95-100% adhesive coverage which is necessary in wet areas.
Checked the adhesive for what you said, and it looks ok to me but he was selling me the rapid one which he said goes off in 30 minutes and I thought that was too quick for me so changed it for the one that takes hours to go off. I thought that would be sensible for me as I could never tile as quickly as a professional.
But which one? If it’s the wrong type of adhesive or sets too slowly, large/heavy format will slide around all over the place on the wall & the adhesive will tale an age to go off before you can grout. Your choice but using Rapidset, or SPF if you feel you need longer, won’t make any difference as long as you only mix up enough to last you the pot life. A 6mm x 6mm x 6mm notch trowel on that size tile using powder addy on an uneven wall is too small won't give sufficient tile adhesion for a wet area.
I will re-look at this when I go back again next week.
I have done my best to give advice, admittedly on the safe side, for your (unseen) conditions but if you wish to take the advice of a tile outlet salesman then that’s fine; good luck
