How to put a 10mm diameter screw into plasterboard?
14 Sep 2005
Milton Keynes
I have a hook with a 10mm screw that I want to put into an internal wall (plasterboard).
I can't find wall plugs wide enough for this. What can I do?
Thanks.
Paul
If the diameter is 10mm that suggests it needs to be quite strong, which plasterboard isn't! maybe screw it into a stud if there are any, or cut a hole in the board and screw it to the wall behind.
