I don't know what my walls are made of, at least behind what's visible, so I can only tell that I have plasterboard and after that there should be wooden studs in a reasonable distance (I'm not sure if that's the correct term, but I mean an house made of stick frame).
I'm thinking on fitting shelves on top of my desks, but unfortunately I don't think it's a good idea because I don't know what's behind.
Checking by only knocking the wall, I can't really find any less hollow sound, I was expecting it when knocking a wooden stud.
So, shall I assume that there is a very big plasterboard or even a single one for each wall?
Even by reading this guide, I can't tell: https://www.ratedpeople.com/blog/wh...n check is to,stud partition walls are hollow.
Assuming the worst, I can tell that they won't hold books and heavy items, so I need to buy something from the ground, like a proper library etc. The issue I'll meet is that it won't have space for my desks, unless I take a specific model but those cost more than 1k and you're limited to that wall where it resides.
If I don't buy very old fashioned libraries, the new ones are very light and they require to be fixed in the wall, I don't think I'll meet the same problem but it may happen anyway if I don't fit it perfectly.
Plus, how would I know the distance I can drill and therefore what size and shape of spreader clips I can use? This video is very detailed, but it doesn't help my job at the end:
I found this detector, is it enough for what I need to do? https://www.toolstoreuk.co.uk/bosch-gms120-professional-multi-detector/p1448
In all this, I wonder how they've fitted the kitchen , there are at least 35kg of stuff up there the shelves.
