Just been reading your post and would like to add a couple of things to watch out for on old lime plaster.
If the house is as old as you think,'1800' then the walls are going to be lime plaster if they are still original, if more modern, then a little bit easier to deal with.
Lime plaster was made up by mixing a lime putty with whatever bulking material was available from the local area, coal dust, ash, furnace clinker, any grades of sand and most likely horse hair to bond it all together.
The problem you will have to watch for, is if you break through any paint surface into the plaster, it will start to break up as it will now be very very very dry!!! Once this starts to break up, you could end up with very deep and very dry holes which will be difficult for you to fill with diy fillers.
BIG trouble!!
Do not use a steam stripper as this will 'Blow' the surface off when the steam hits the lime mortar, it will make a popping sound as the wall breaks away inside.
I suspect you have found that some of the paint flakes off fairly easy from the paint surface that you have and that you want the wall to look all old and patchy rather than paint it over, if this is the case, just scrape off what you can and give it a coat of matt water based varnish.
