I was trying to use my **** bosch sds drill to drill through one skin block and one skin brick. I need a hole for a cable feeding the security lights. The issue is the joist was very close to the wall. I thought I'll drill from the outside in. I was told to drill a hole through the joist then a very long ass sds drill bit through the hole. I couldn't fit a drill between the joists hence I had to do it at an angle. Now it's properly wedged into the wall. The drill won't reverse it out. I regret not following my instinct now.
So does anyone how any bright ideas on how to remove it. I have tried grips. I have tried knocking it side to side with a claw hammer.The BASTARD wont move
