- Joined
- 1 Sep 2021
- Messages
- 6
- Reaction score
- 0
- Country
Turning 16 volt to 12 volt reasonable easy, a 7812 chip can do that, but 11.5 to 14.8 volt to 12 volt not so easy.
OK, I'll try a 7812. Maybe 1.5 amps is ample for normal use and it only needs 2.2 amps in exceptional circumstances such as flashing new firmware or re-tuning. Or maybe the speaker wouldn't go as loud at max volume.
A normal diode will have around 0.6 volt drop across it, a red LED around 1.2 volt, a white one around 3 volt, but the problem is 2.2 amp is over what you can drop with cheap devices, so you need some thing like thisbasic idea it turns DC to AC transforms it and then changes back to DC and it alters the mark/space ratio to maintain the voltage.![]()
The reason I'm making 12v power supply cables is to avoid using an inverter, which wastes power by turning it into heat and then running a fan to dissipate it. The battery is charged by a solar panel, so needs to last the night. But Battery Guards also avoid damaging the battery by totally discharging it. And there are versions that indicate how much power is left in the battery, which would be useful to know. And not expensive, so maybe worth adding to the system.
