How to wire thermostat?
could be :D
Connect it as the others say and not use the blue one.
If it either dont turn on or stays on you will know that the contacts are stuck together.
It is basically just a switch between the Red and Yellow wire.
That link to the datasheet says no neutral connection needed to thermostat. So just red & yellow, the datasheet shows you where.
