Ive got several fittings from different makes, most work together but not all, yes the brass style fittings do seem to work better/longer, I found the biggest problem being the 'O' ring on the male ends degrading, some are silicon, some are more plastic based & flatten easily, resulting in a 'no lock' situation. The solution was to buy a pack of suitable sized silicon rings & replace all.
