I've just fitted my new HRM wallstar through the wall and the outside doesn't look right to me. The outside cabinet door lifts off. It is held by 4 screws in L shaped slots so you loosen lift it up then forward. Around the flue is a metal plate that slides in the door to allow you to do this. The clearance between the metal plate and the flue is at least 3mm. So there is a small crescent shaped gap where rain could get in to the burner area.
Are they all like this? I wonder if the wrong metal plate has been fitted say for the higher output models, if they have a larger flue.
There is bulge in the flue, that is a V shape in cross section. Flue diameter increases by say 6mm. If this was flush with the metal plate and then it would fill the gap. However the bulge is about 6mm away from the plate so it doesn't.
