Hysteresis said:
I read somewhere recently of the development of a Hydrogen Fired Central heating system which uses Natural gas as the fuel source. The combustion of the Hydrogen is virtually pollution free and the energy output of the Boiler is 25% greater than that of a similar Narural gas fired unit.
Hydrogen combustion is indeed pollution free because the only combustion product is water but what happens to the carbon?
I can't see any way of getting 25% more energy out of the original methane if you don't burn the carbon as well.
Presumably these devices work by breaking down CH4 into Carbon and Hydrogen. The Hydrogen will be used as a clean fuel, but what happens then to the carbon that is left. Is Carbon in gaseous form not a pollutant like CO or CO2.
Carbon doesn't exist in gaseous form at the temperatures found inside a domestic boiler. Try an old fashioned carbon arc sun lamp. My grandmother had one.
Carbon itself is dirty but inert. In that sense it's not a pollutant but I just don't believe that this new boiler isn't oxidizing it somehow.
namsag said:
Heard about 8 years ago that BG where developing some sort of power source that gave out more energy than was put in but not heard mention of it for a while
That'll be because it didn't work. It's time the infamous cold fusion experiment was put to rest.
We need a proper investigation into what really happens when you expose certain metals to monatomic hydrogen.
there is a growing theory that oil is not actually a fossil fuel and is a by product of what happens within the earths core
It's a plausible theory that oil, or at least methane, is oozing out of the core and mantle. There was a lot of methane in the early solar system; the gas planets still have most of theirs. On the other hand, I'm sure the biologists are right. At least some of the oil is formed from the anaerobic decay of organic matter.
Hysteresis said:
the output of the fuel cell is electricity but DC. In order to use it domestically therefore it will need to have an invertor of some kind which are not 100%
That's not a problem. The waste energy from the inverter is heat - which is what the boiler is primarily there to provide.
The idea of selling spare power back to the electricity supplier isn't that ridiculous - but will they believe the meter when it's gone backwards?
I am assuming they use the petrol/diesel engine to drive a larger alternator than the vehicle was originally supplied with and then use this alternator to electolysise water and use the resulting Hydrogen to fuel the engine. Quite how it can produce enough Hydrogen to do this is a little puzzling, but that how I assume it works.
It's a scam! You can use engine power to drive an alternator to split water but you can only get a fraction of that power back by burning the hydrogen in the engine. You are using high grade, ie zero entropy, kinetic energy to produce equally high grade electrical energy which is then used to get hydrogen out of water. And what do you do with the hydrogen? You burn it in the engine!
Result; most of the energy goes out of the exhaust pipe as heat. WDIK has said it:
WDIK said:
basically there is no working example of an over unity fuel cell, you cant get out more than put in.
Hysteresis said:
You can appear to get more out than you put in. Just look at the internal combustion engine. What happens is that you release what was put in by nature millions of years ago. The Fuel cell is just another example of a way of releasing the stored energy.
But you can't get more out than nature put in. Fossil fuels are just stored solar power.
Now fission certainly produces more than WE put in, that energy was provided at the Big Bang.
Not quite. The energy in heavy nuclides was put in when some dying star imploded. That was certainly a very big bang but not THE big bang.
Fusion however at this point in time does require greater input than output presumably because we are trying to create our own little 'Big Bang'.
What we are trying to create is our own star. The fusion reaction itself is well understood. What makes it difficult here on Earth is that we lack the gravitational field of a real star so we have to devise an alternative, magnetic, container. It would be fair to say that the energy input was supplied by THE big bang. If the theory is correct, it made the protons (hydrogen nuclei) which stars fuse into the more stable helium.
I'm delighted I don't have to work in those conditions in order to survive, maybe that is the very reason we are all so obsessed with energy these days.
You certainly got that right!
