Hi all,
Last resort here. Please bear with me as I will try and provide as much info as I can at the start!
I have a 18 year old Y-plan vented system with potterton suprima, 13 rads (6 down and 7 up) and indirect coil water heating. Pump is Grundfoss (max speed III), mid position from Drayton (MA-1). TRV is TRV4 with temp set to max and internal regulator at 6 (fully open). The TRV has a 15mm to 10mm reducer fitted as the radiators have 10mm pipes going to the walls where they join onto 22mm pipes that run throughout the house.
The Problem.....
Every morning the heating and hot water turn on. Both work, but he radiator in the Main bedroom starts to make a gurgling sound. This gets louder with a squelching noise as the pump/boiler turn on and off. It gets louder as things heat up.
As time goes by the gurgling/bubbling/squelching noise fades, even with pump start and stop cycles, but then the radiator decides to get even more annoying by making popping and crackling sounds. These can be loud and both sounds are enough to wake me up!
I have tried...
I have bled the system in the airing cupboard (high point above the heating coil in the imersion tank), bled the pump and still it goes on.
I have bled the radiators time and time again. I have bled them cold with no pump, and hot with the pump running and alternately closing off the TRV or lockshield to remove air from the feed and return pipes.
I have tried running the pump at speed II and III, still no cure.
I tried a tube of Screwfix concentrated cleaner a couple of weeks ago. Left it in for a couple of weeks and drained out and flushed through. I now have some Sentinel x800 to try next!
I have found...
Whilst investigating, I notice the F&E tank was full of black water with brown mud in the bottom and white bits (so far unidentified) floating on the top.
Turning off the hot water seems to help reduce the gurgling/whooshing noise and also seems to move the source of it from the radiator to further down the pipes towards the boiler.
Hot water and heating both work well, all rads are 60-70+C.
I am stumped.
Any genius know what to do next? (apart from installing electric heating or moving house!).....
The Problem.....
I have tried...
I have found...
I am stumped.
