I damaged 9.5kw electric cable that feeds my shower
a properly crimped
What odds are you offering on the OP having a proper crimping tool?
and even soldered joint
With the mechanical strength provided how?
There is a screwed connection at the isolator on a shower cable anyway!!
Indeed.
And it's not at all unknown for them to go wrong, i.e. they are risky.
Why advise the unnecessary introduction of a risky joint?
I wasn't thinking the OP would have the tools to crimp or solder a 10mm cable, but was saying that an electrician could possibly do this. Everyone before hand was saying that he HAD to have a complete new cable installed. I am saying that yes in an ideal world that would be best, but it isnt an ideal world is it? And there is another option.
If you drilled the cable fitting the shower then is the damage close to the end of the cable anyway, you might get away with the crimp within the shower unit somehow, or maybe move the shower to suit the length of undamaged cable
I dont know why everyone is saying to re new the whole cable, a properly crimped and even soldered joint would be ok. There is a screwed connection at the isolator on a shower cable anyway!! :confused:
Replacing that whole length of cable has to be the preferred and superior best option. I would then expect the op to say how possible this is, and if it's near impossible then would look at ways to maybe repair the cable.
No.
Nor because you never are (IHNI about that).
But simply because you are wrong - jointing the cable should be avoided if at all possible, soldering is a dreadful idea, and screwed joints do fail.
And so do some crimped joints. Even if made by a qualified and experienced electrician using the right tools there is still a risk of failure.
Either way the biggest arse in changing the cable back to the isolater (assuming it has one) will be the tiling and short of having a join behind the tiling in the shower area your not going to get around that.
Unless as said, you move the shower unit down to meet the undamage section if its is that close.
Daniel
