- Joined
- 11 Jan 2004
- Messages
- 46,216
- Reaction score
- 3,653
- Country
I suppose what I'm saying to sceptics is that it is perfectly possible to achieve safe isolation, but I didn't say it was quick & easy.
Total and utter rubbish: see above.
For those switches my lock-off device does not fit, I use MCB lock-off clips. Failing that, I will remove conductors or lock-off the main switch (which it is vital to do with TT supplies anyhow).
This is also how I would deal with the possibility of breaking a neutral & making it live: lock off all poles of all circuits within the property: a lock on each main switch feeding that property.
Your post appears to demonstrate a very limited understanding of safe working practices.
You must be a DIY'er then.
Qualifications and training - (started 1965) - Indentured apprentice, C & G: A; B; C; T4; T5; Electricians' Certificate and two Full Technological Certificates (one for course C and the other for T4 & T5) - not to mention other higher qualifications in engineering and computer science
I don't think it's an age thing - it's down to training and self-discipline....typical of an older electrician:
"I've always done it this way and it hasn't killed me yet, so I must be doing something right..."
But absolutely no respect for your own safety. You think that safe isolation is not achievable, typical of an older electrician:
Always assume that conductors are live, and only touch the copper when you have checked it individually just prior to working on it.
You say "see above" - I've looked above and I can't see any reason for you to take umbrage at what I wrote.Well, see above says it all - I had a higher opinion of you - obviously misguided.I don't think it's an age thing - it's down to training and self-discipline....typical of an older electrician:
I don't know what you've understood and what you've misunderstood - I'm not inside your head.Now if I have misunderstood that then I apologise.
If you hadn't thrust your qualifications up his nose in such an obnoxious way, it's possible that that he wouldn't have made that comment, so I'll just stand aside while you continue your petty bickering directly with him.In my opinion he has failed to understand my initial comments, and has assumed that because I criticise 'safe isolation' procedures I must therefore undertake the, usually unnecessary and potentially dangerous, practice of working on live equipment.
