I have a flat which is in occasional use. Fitted with 3 x night stoarge heaters, it keeps the place warm but also when Im not there. The ideal situation is to fit a 7 day timer so I can have the heaters on for only 3/4 days a week to reduce running costs while keeping out damp.
The question I have is where is best to fit a timer, ideally each with its own so I can cycle the heat throught the place.
For instance can the DP switch at each heater be replaced with a single socket and a 20amp timer used with a plug fitted to the heater?
I know I can have a relay fitted at the CU but this would switch on all of the units at the same time.
I am time servced but left the trade a while back and not up to the latest regs. I will be employing an electrician to do the work with current part P. I just would like to know options if anyone can sugguest please.
