i was trying to repair an idea isar he35. the problem the customer is having is when the hot water is running it make a whirring noise intermittently. i have done several test.
when c/h is on the flow got upto 65 degree hot
return got 52 degree hot.
gas rate was correct as per manufacturers
the system pressure was correct, and no air in system and the bypass was open.
gas valve white tube is not damage and the boiler is not leaking.
the ionisation probs are correct
flue gas analysis test is also correct.
inlet pressure at gas meter and boiler 21mbar.
standing pressure about 27 which are correct.
what i found strange is when the whirring noise accurs the inlet pressure on the boiler got as low as 16mbar, but on the gas meter it was 21mbar.
when the noise does not occur the inlet pressure is corect on the boiler.
the boiler is only about 2 yrs old and recently powerflush with a magna clean, the pump, divertor valve, thermisters were all replace recently. at first i assumed it could be a blockage but the reading am getting appears ok.
i have ordered a new gas valve because on the low inlet preesure when the whirring noise happends and new thermister. the only other thing it could be is a blockage in the plate to plate or the fan is damage.
Any ideas on this problem would be greatly appreciated.
Thanks.
Thanks.
