Ideal HE12 Boiler still thumping
Thanks all.... Dropped Allen a message.. Lets see what he thinks.. If its the Main Exchanger which is at fault, I guess its time for a new boiler?
I will check out the pump at the weekend and see what it looks like.. The only reason why I don't think its the pump is that it has a variable speed slider on it and I have changed the speed and nothing changes.. There is no science to this belief, but I figured that if it were the pump changing the speed would have SOME effect?
This is interesting as another problem in the house that I am investigating is an on/off low hum when the heating and/or water is on.. It only happens occasionally making it hard to debug.. But I have traced it to the airing cupboard and specifically the tank.. But its crossed my mind that the source of the sound could originate from somewhere else (i.e the boiler), even though you can't hear it downstairs at the boiler.
Does this mean anything to anyone?
Replace any float valves in the cold water storage tank and expansion tank in the loft.
Andy
T
Yes, I don't think it's likely to be the culprit, but it's not a big job to eliminate it.
