Hi to all, i'm the family ex heating engineer Grahamj spoke about thanks for the replies.
When i first looked at the boiler checked the usual, ie gas at inlet, earthing at various points, etc. At the time the boiler was working intermittently hence leading me to my initial instinct that it was the flame detection electrode. Having replaced that it seemed to work fine.
When the fault happened the second time i looked further into to it removing the fan and burner cleaning the heat exchanger,sump and condensate. Which apart from slime in the condensate was not in bad condition for a 4 year old boiler.
Reading through the fault diagnosis in the manual the next logical part to replace was the PCB, although reluctantly.
Now the boiler is still not working, there is a dip in gas px at the inlet as the boiler tries to start. If standing by the flue terminal then it is possible to hear the spark generator (which has also been tested and re-positioned) a ignition sound is heard also followed by a slight raise in temp but immediately it cuts out.
I admit i am at a loss
, its not as if i can actually see whats happening inside the boiler ie the flame path etc but everything is set up correctly. So any more useful ideas would be most welcome... luckily it'll be summer soon!!!
D.
