Ideal Isar boiler H 3 problem
Status
Not open for further replies.
...Now can a punter change a PCB or not?...
Like I said: your generalisation can't be answered any more accurately than "is an Englishman permitted to drive a car?" or along the analogy of cars: "are cars blue?"
Some are, some are not.
So some punters can change a fan? Spark electrode? Vacuum jobbie diaphragm? PCB? Gas valve?
I'm waiting for your answer. :rolleyes:
And Likewise I am waiting for you to tell me what zero rated governor equipped boilers are fitted with your vacuum sensing device.
Ben has answered you perfectly; but the sub text you are looking for are the magic words competent; and there is only one way t prove competency.
No "punter" as you put it can change a fan or gas valve on a modern boiler, simply for the fact that they win't have a calibrated FGA or the competency to use it.
Likewise they can not breach the combustion chamber on many modern boilers for the same reason.
So can they calibrate a PCB? If they can - you better tell MOD 14. :confused:
And why would you need a FGA when you change a fan? It's a like-for like change.
Ain't gonna tell you. It is giving out DIY gas advise.
Status
