- Joined
- 12 Jan 2006
- Messages
- 77
- Reaction score
- 1
- Country
Hi all,
I have IDEAL ISAR combi boiler, 14 month old. The problem is that when heating is OFF radiators are hot/warm so house is to warm. After reading manual and conducting some observation I can find the following:
Periodically burner is ON to heat up internal DHW plate exchanger, according to manual. When this takes place display has "t" as per manual. The problem is that this lasts quite some time and radiators are getting warm/hot. Process repeats after several minutes. The end result is that radiator without TRV is hot others are warm as valves is closed. Last nigh house got so warm I had to turn off the boiler off at the mains.
If I use DHW there is "d" on display as expected but when DHW is closed "t" appears again and burger is "on" for some time after DHW tap was closed.
There are no leaks or dripping taps on DHW.
I suspect some problem with diverter valve but perhaps there is different reason? any advice?
If it is diverter valve can this be cleaned/repaired or are there parts to change rather than entire assembly and housing?
If I need to change diverter valve any tips or things to look for?
what could be cause for diverter valve failure, CH system water should be cleaned, system was refilled when boiler was fitted by British Gas .
Just out of warranty, typical...
thanks
thanks
