I was called out today to look at the above named boiler, the pump was not running for the c/h so i replaced that and the c/h now runs fine, however the dhw has zero pressure at all, can anyone advise me on this please?
is there any water coming out the hot water tapSorry ya, cold water pressure is fine and the valves are fully open, i am a plumber by trade but have not worked on this type of boiler before
I think he means the one that I do - second from the right. You can turn it off and remove the cartridge inside - this is the pressure regulator bit.
