you can't help yourself can you?you must have some issue's with ideal?,grow up and get over it,if you knew anything the exchanger would take up to 25 years until the corrosion affected it
If you stopped believing the propaganda that head office feeds you about how good the boilers are and everything is an installer fault, then perhaps you could look at things in a better perspective.
Where does all the aluminimum oxide sludge come from then, if not the HE?
Yes I have got a problem with Ideal. They conned me into fitting loads of Isars/Icos boilers, then after about 4 years they need new HE's, apart from all the other costly problems that are associated with them.
Head off call centre is carp, they are all, except Dave Kemp and techy, apparently programmed to say it's the installers fault and .thats not under warranty'
The only ones I do not have a problem with are you engineers in the field. Apart from two, one from the London area who had to cover my area for a short while and one who has since been sacked, they have all been very good.
There has been a quite a high turn over of staff so they must get fed up with the hassle of working for Ideal
