I have just moved in to a new house which has an Ideal Mexico Super CF55 fitted.
The previous owner moved out the day before and tells me the boiler was working.
Next to the boiler, there is
* Switchmaster S400 switch
* drayton Mid Position Actuator
* Grundfos Selectric ups 15-50 pump
With the switch set to "constant" and "hot water", the pump runs constantly (EDIT: or at least it makes a noise) but the boiler only fires up for about 5 mins before stopping burning (pilot light stays lit). EDIT: the pipes entering the tank from the boiler do warm up, but apparently not enough to heat the water noticeably. I get water out of the taps but not hot water.
I haven't yet checked whether the boiler remains running if the CH is switched on. EDIT: now I have, with the CH on I have the same problem. Boiler burns of 5 mins, radiators do not heat up.
My apologies if I have missed any obvious important info out, I am totally green when it comes to looking after a boiler and very grateful of any help.
