C
customtimber
The adjustable pads are on this website
http://www.thegardenroomguide.co.uk...ration-of-garden-room-foundations/2010/03/12/
Im not sure on cost but to be honest as long as your block work is level and square in the first place then you should not need them. With regards to the foundations since it near to a stream that may/may not rise we generally dig down to the water table and install a full rebar cage and infill with concrete this general go's the whole width of the face of the building plus returns at both end to tie back this prevents the weight of the building causing subsidence. ignor previous if at least 1.5mtr from bank . If you are doing pads and subframe then be sure to use 'Solid' concrete blocks NOT 'Dense' (these will crumble under pressure).
If required i can provide you with a Pads and Subframe plan if you provide floor dimensions of building.
Hope this is some help.
