The previous owners of my house decided to take the TV distribution amplifier with them when they left, understandable I guess if they'd recently paid for it, but annoying as they didn't label any of the cables. Result: I had 7 identical coax cables running to a location in the loft and no idea which is which.
So I applied a bit of brain power to it and realised if I went round the house shorting out the 6 TV sockets one by one and DC circuit testing them from the loft, I'd be able to tell which was which and whichever one was left over must be the aerial feed. So I did this and identified all the sockets in the house, wired them into the new amplifier and finally connected what must be the aerial line to the input of the amp.
Ran downstairs to check it all worked... NOTHING. Not a single channel. Bugger.
So I went back into the loft and connected what I thought was the aerial directly to a small LCD TV and did a channel scan, nothing again. So I started Googling and discovered that apparently a UHF aerial can look like a dead-short to a DC circuit tester. Suddenly I realised my whole identifying of cables might have had a fatal flaw. So painstakingly one by one I tried every cable directly into the TV and did channel scan. To my ultimate frustration, none of the cables produced a single channel.
Any tips on what to test or look for next? All I have to hand is a DC multimeter (which I understand is woefully inadequate for this job) but I'm trying to save a bit of cash here. I'm fairly certain the cable I've identified as the aerial feed is indeed the aerial feed as it comes from the right place on the house. When tested with a DC tester there is no circuit (infinite resistance) on this line. Is there a way to test for the presence of an aerial on a wire with a DC/AC multimeter?
Thanks!
Thanks!
