masona said:A silent vacuum cleanerbreezer said:what would you have?
Put your foot down, tell her to be quiet !!
Self burying pedestrians and cyclists !!
Self rearing children !!
Still on the subject of TV. A system that turns down the volume when a compressed audio signal is detected, saving that effect of having adverts blast out, in the middle of a film.
In the good old days the volume of all programme and commercial breaks wre monitored and adjusted by whats called CAR at the BBC and usually these days at other broadcasters MCR whether it's because of money constraints and moral amongst staff that quality is dropping regarding the monitoring or my theory that it is done on purpose these days to attract your attention to the adverts who knows?AdamW said:That would be good! I have found this especially bad with Sky: presumably for sound they now have a much bigger dynamic range to play with, so the adverts appear even louder. Whats really bad is when I'm watching something really atmospheric and dark (so volume up quite high), then I go to attend a call of nature and can hear the "borrow your way out of debt" adverts blasting at 120dB (I am baffled as to what "babble you with science" means!)
Another look at Budgies (Adam faith) girlfriend from the 60's tv series of the same name ... Margaret Nolan I believe !!!!What would you have?
TexMex said:Another slant on the TV adds annoyance. How about a TV where you can select two channels simultaneously. You then watch one, while it records the other, During the adverts, it switches over automatically so you catch up on what you've missed on the other side.
pipme said:Plus a unit attached to home electrics which will monitor everything at the press of a button ... current flow in cables, resistances... a full analysis !! usage and safety ..
P
Welcome to Sky +, does that apart from the viewing automatically which you do manually (more control that way).TexMex said:Another slant on the TV adds annoyance. How about a TV where you can select two channels simultaneously. You then watch one, while it records the other, During the adverts, it switches over automatically so you catch up on what you've missed on the other side.
