yes, as part of my loft extension my builder has arranged for my electrics to be Part P certified by an electrician since the CU was replaced. After his initial visit there was some remedial work required (below) which i have volunteered to undertake. my first question is in regard to earth bonding, i am planning to run the cable from the bonding clamp on the gas meter under the floor and into the kitchen
4) There is no water bonding to the water stop valve in the kitchen below the boiler.
5) There should be 6mm supplementary earth bonding to the boiler pipe-work
So, do i need to bond a all the boiler pipes as well as the water main? also, do i run the cable back to the gas meter or CU?
My second question is about modifying a circuit;
2) The kitchen is wired mainly on two radial circuits, one for the boiler and there are about six sockets connected to the sockets on the left hand side. There is a chance of overloading this radial circuit.
I can connect this to the ground floor ring main but what is the best method, junction box, terminal block? ideally i would extend the ring between existing sockets but this may not be possible
