im making hydrogen fuel cell amperage question
9 Feb 2008
using .5mm stainless steel 316 wire coiled round a spool
3 metres of it to start
using 12v battery
my guess is itll be pulling between 2-4 amps
at how many amps does the wire get hot to the point of breaking?
what amp fuse should i use?
its critical because fuel cell container has highly explosive gasses
appreciate info
thanks jikwan
i assume your hoping for cheap fuel!!!!!
unfortunatly the cost of electricity to convert to gas makes it about £3 a litre petrol equivilent :rolleyes: :rolleyes:
some stick an extra alternator on and so what? an extra alternator
hydrogen massive potential
Except the energy taken from the engine by this extra alternator will be greater than the energy which you will gain back by burning the hydrogen fuel made by the system.
Theres no such thing as a free lunch!
there is a free lunch
many big name scientist have been murdered because they discovered the free lunch our own tesla got given a very hard time
check out the awesome orgone energy
Adam - give it up, it's pointless - jikwan does not accept that the laws of thermodynamics apply to him.
im throwing the towel in
no way am i going to mess with heavyweights on this forum
can anyone just give me a clue about how i can select the right fuse please?
Wire an ammeter in series with everything, adjust the rheostat so that the wire gets as hot as you ever want it to be able to get, record the value and pick a close value of fuse
adam
commonsense isnt it?
i would never have thought of that in 100 years
thanks for that
Do I detect a hint of sarcasm...
... anyhow, if its common sense, how come you came on here asking the question? :?:
adam
no sarcasm, really maybe just my way of using words
im so thick just pointing out how thick i am
i thank you for helping me
why on the forum? precipitator question my last topic
heeeelllooo jikwan
i think what your missing is the fact that the amount of gas being produced in your utube clip is only a fraction of the amount needed to run an engine
at 5000 rpm you have 5000 explositions a minuit thats a lot of gas :rolleyes: :rolleyes: :rolleyes: [assuming 4 stroke 4cyl]
you also need to compress the gass to allow storage or hav a highly explosive bag upstairs :D
http://www.edinphoto.org.uk/0_stree...waverley_bridge_gas_bag_bus_ed_s_1900_049.htm
good luck with your experiment :D :D ;)
