hi big all
sure that rough test shows 1 metre of wire used
produces small amount
my idea is to use a spool aprox 1 inch dia x 5inch length
wrap wire round probably 1mm space between wire
one continuos wire
about 6 metres per cell
4 cells =24 m of wire minimum could be a lot more
wire is neg
i need figure out posative plate arrangement
my guess is it could produce between 1-2 litres of hho per minute
thats running it on the bench
connect it to venturi of carburettor from the outside where theres a vacuum
i believe vacuum increases production x5
thats a possible 10 litres of gas per min
10 litres of compressed hydrogen ibelive should either knock down a brick wall
or else make a big hole in it
12v 2-4 amps how many watts is that? maybe 30 watts per min?
one continuos wire
wire is neg
