Hello,
I moved into my flat around 20 months ago (all electric) and soon replaced the Horstmann controller to my immersion heater (Harton) as it had burned out (only able to manually turn it on, not timed).
When replacing it I only had to replace the front cover with a Newlec one (just a modern Horstmann type), plugged the 5 internal connectors together and it worked well up until now (i.e. for the past 17+ months).
NOW when the controller is turned on, irrespective of any timed settings, it will straight away turn on my top element (which starts hissing away) - if the boost is turned on or the time reached for the "timed boost" setting it seems the second element (bottom one) will also turn on and BANG goes my 16amp fuse (i.e. 6kW rather than 3kW) - their both 3kW rated.
I may be stating the obvious - but this is a controller problem and not an element one?? I'm not much of a plumber/electrician, but I took off the caps to the elements just to have a look and all seemed in order (cables, water temperature control).
Could a corroded element cause this problem or do you think its all to do with the controller (though its just under 2 years old!!). Is there some electrical checks I could do??
Any help would be appreciated - Thanks.
