I've added a clearer pic.
I'm 100% positive that switch 2 (the broken one) is wired to an MCB in the standard CU and that switch 3 is wired to an MCB in the Eco 7 CU. I'm not quite sure how I will verify which element they control as the wiring is out of sight and awkward, but I'll give it a go.
You've got me worried now. I guess the best case is that I have two switches that do the same thing i.e. heat the top element on demand (1 & 3), which seems strange but possible, and that only the MCB is broken (which incidentally is 20A anyway).
After the heater went dead I looked through my energy bills and realised that eco 7 is incredibly expensive for me, so I've arranged to go onto a 'normal' tariff. As a result someone will be replacing my meter tomorrow - this should give me an opportunity to find out a bit more about the wiring, though I'm sure the engineer wont want to waste any time fiddling around with my dodgy immersion heater!
Thanks to all for the advice so far. I'm keen to at least work out what is wrong before calling in an expert.
If Switch 2 and Switch 3 both operate the lower heater, and one is wired to the Eco 7 CU but the other is wired to the normal CU, that is WRONG and DANGEROUS.
